Фризы в CS2 при высоком FPS | Ноутбук MSI GP66 Leopard
MuxauJl
Модель ноутбука: MSI gp66 leopard
фризы
Вечер добрый, поигрываю в КС2 средний FPS в ММ режиме 180 фризов нет, как захожу в ДМ FPS тот же, но начинаются лютые фризы, играю с монитора 27 дюймового. В чём может быть причина заранее спасибо?
Number of cores        6 (max 6)
    Number of threads    12 (max 12)
    Manufacturer        GenuineIntel
    Name            Intel Core i7 10750H
    Codename        Comet Lake
    Specification        Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz
    Package (platform ID)    Socket 1440 FCBGA (0x5)
    CPUID            6.5.2
    Extended CPUID        6.A5
    Core Stepping        R0/R1
    Technology        14 nm
    TDP Limit        45.0 Watts
    Tjmax            100.0  C
    Core Speed        4489.0 MHz
    Multiplier x Bus Speed    45.0 x 99.8 MHz
    Base frequency (cores)    99.8 MHz
    Base frequency (mem.)    99.8 MHz
    Stock frequency        2600 MHz
    Max frequency        5000 MHz
    Instructions sets    MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
    Microcode Revision    0xE2
    L1 Data cache        6 x 32 KB (8-way, 64-byte line)
    L1 Instruction cache    6 x 32 KB (8-way, 64-byte line)
    L2 cache        6 x 256 KB (4-way, 64-byte line)
    L3 cache        12 MB (16-way, 64-byte line)
    Preferred cores        2 (#4, #5)
    Max CPUID level        00000016h
    Max CPUID ext. level    80000008h
    FID/VID Control        yes
ID            0x10B0104
 Name            NVIDIA GeForce RTX 3070 Laptop GPU
    Board Manufacturer    Micro-Star International Co., Ltd. (MSI)
    Revision        A1
    Codename        GA104
    Core family        0x174 (GA104-A)
    Power Limit        125.0 W (default)
    Thermal Limit        87.0  C (max), 98.0  C (slowdown), 101.0  C (shutdown)
    Cores            5120
    ROP Units        96
    TM Units        320
    RayTracing Cores    40
    Tensor Cores        160
    Technology        8 nm
    Memory type        GDDR6 (Samsung)
    Memory size        8 GB
    Memory bus width    256 bits
    Current Link Width    x16
    Current Link Speed    8.0 GT/s
    PCI device        bus 1 (0x1), device 0 (0x0), function 0 (0x0)
        Vendor ID    0x10DE (0x1462)
        Model ID    0x249D (0x12EE)
        Revision ID    0xA1
    Root device        bus 0 (0x0), device 1 (0x1), function 0 (0x0)
    Performance Level    Base
        Core clock    1215.0 MHz
        Memory clock    7001.0 MHz
    Performance Level    Boost
        Core clock    1620.0 MHz
    Performance Level    Current
    Driver version        31.0.15.4617
    WDDM Model        3.1
DMI Memory Device
    designation        ChannelB-DIMM0
    format            SODIMM
    type            DDR4
    total width        64 bits
    data width        64 bits
    size            32 GB
    speed            2933 MHz
    manufacturer        Kingston
    part number        KF3200C20S4/32GX
    serial number        6713116F
    voltage            1.200000
    manufacturer id        0x9801
    product id        0x0
добавил оперативки
  • A+ изменил название на Фризы в CS2 при высоком FPS | Ноутбук MSI GP66 Leopard
5 часов назад, MuxauJl сказал:
Надо было на Райзене 5ххх брать, как у меня. Хоть и видеокарта слабее (3050Ti), но никаких фризов при FPS в 150+. Специально сейчас погонял deathmatch с ботами - всё прекрасно. Это, конечно, больше шутка, чем реальный совет, но тем не менее...
Что есть ММ и ДМ режимы?
Если жалуетесь на фризы, то надо эти фризы показывать. Запишите видео из игры со включённым мониторингом и чтобы линия фреймтайма обязательно была.
ДМ-это deathmatc c ботами 200+, онлайн меньше в районе 180 . С проблемой разобрался сам, фризы из-за проца были ,сильно грелся под нагрузкой, понизил питания проца упала  естественно частота , но зато больше 75 не греется)
7 минут назад, MuxauJl сказал:
Я сразу сказал, что надо было Райзен брать.
