Закрыто [Не прошла модерацию]: Перезагрузка ПК при входе в игры (сначала вырубается видюха,потом остальное). Ниже приложил дамп.
************* Preparing the environment for Debugger Extensions Gallery repositories ************** ExtensionRepository : Implicit UseExperimentalFeatureForNugetShare : true AllowNugetExeUpdate : true NonInteractiveNuget : true AllowNugetMSCredentialProviderInstall : true AllowParallelInitializationOfLocalRepositories : true EnableRedirectToV8JsProvider : false -- Configuring repositories ----> Repository : LocalInstalled, Enabled: true ----> Repository : UserExtensions, Enabled: true >>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.016 seconds ************* Waiting for Debugger Extensions Gallery to Initialize ************** >>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.094 seconds ----> Repository : UserExtensions, Enabled: true, Packages count: 0 ----> Repository : LocalInstalled, Enabled: true, Packages count: 41 Microsoft (R) Windows Debugger Version 10.0.27553.1004 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Windows\Minidump\071824-9937-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: srv* Executable search path is: Windows 10 Kernel Version 19041 MP (12 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Kernel base = 0xfffff805`2de00000 PsLoadedModuleList = 0xfffff805`2ea2a820 Debug session time: Thu Jul 18 13:44:26.232 2024 (UTC + 4:00) System Uptime: 0 days 0:20:05.897 Loading Kernel Symbols ............................................................... ................................................................ ............................................................. Loading User Symbols Loading unloaded module list ...... For analysis of this file, run !analyze -v nt!KeBugCheckEx: fffff805`2e1fdde0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffffd01`a97bfa00=0000000000000116
Доброго времени суток.
